I am in the market for a used enclosed trailer. I do not want to have to upgrade to a 3/4 ton pick up. Does any one use a 1/2 ton pick u to pull a 4 place enclosed with 4 sleds in it? How does it handle on slick roads?
The only way that I would pull a 4 place with a 1/2 ton is if it was a Floe with a Protector cover on it. Otherwise you are asking for an accident or a damaged vehicle.
I had a 24' Pace 4 place that I pulled with a 1/2 Ton. It was white knuckle driving almost the entire time. I wouldnt let anyone else drive it for fear of them crashing. The 1/2 tons just dont have the suspension, power (most of the time) or brakes for that matter.
Now I have a 2500HD and a 2500 Suburban and they make towing that trailer a dream.
As for the Floe...
These trailers are perfect for the guy that wants a enclosed trailer but doesnt want a 3/4 ton. The Protector cover from Floe gives you the light weight pulling from an aluminum open trailer with the basic enclosure that keeps the sleds out of the elements. My friends and I pull a 20' Floe with a 1/2 ton pickup Ext Cab, a 1/2 ton suburban, and a 1/2 ton Tahoe. All have the mass and power to handle that trailer on the slickest roads.
Only drawback... Floe (although I feel makes the best "open" trailer out there) has pathetic brakes. Hardly worth mentioning that they have brakes.
Anyway, these are my .02 but If you have to pull an enclosed with a 1/2 ton, go for a Floe with an enclosure or something similar. ESPECIALLY in the mountains.
you may be able to tow a 27 footer with a honda civic if you can get it hooked up, some of you guys are missing the point, your vehicle has a specific gvwr and towing capacity. Check your weights, it's your life, only it is usually the innocent bystander that gets injured or killed. If you are in an accident and someone sees your load AS IN POLICE, you may want to think of this again. you may have insurance canceled, fines, sued by injured party, man long gone you must have the cash, to take this kind of risk, I would love to have you crack a fender on my ride as I would maybe fill the truck box with a bit of your cash.
Check your weights, Brakes etc, as you are likely overloading your truck, Dot's will love you.
Maybe this is a joke question, You're Very Funny
just a suggestion here...I custom stud my own tires...and while I know alot of states dont allow studs..if you can use them..you should..stock studded tires normally run about 100 studs per tire..we find that putting 300 + adds lots of control..I run 650 in each truck tire ..as well as 200 in each trailer tire on my 4 place...I also run trailer brakes on both axles...even on the slickest of days it handles about the same as on rainy pavement.....towing with a half ton wouldnt be a problem...
I also cannot put enough emphasis on the need for a good equalizer hitch with bars.... all the difference in the world when it comes to minimizing trailer wag/sway from wind/passing vehicles/etc... hard to find a setup for most v-nose trailers tho.
