MPI STANDALONE FUEL INJECTION SYSTEM
(Not a piggyback! 100% designed for snowmobile from the ground up)
This System will only be sold for use on Mountain Performance Supercharger kits and Impulse Turbo Kits. Contact Impulse directly for retrofits on your Impulse kit. This system is a technological advancement unequaled in the snowmobile world.
[FONT="] This computer is a custom designed, standalone EFI (Electronic Fuel Injection) control system specifically designed for use on boosted snowmobiles. This system completely eliminates the factory computer's control of the fuel injection.
[/FONT]
[FONT="]
[/FONT]
Unlike all other systems available on the market (including out older GEMS system) this unit is standalone. We refer to all the other systems available as "Piggybacks". The Piggyback's job is to fool and override the factory computer system into performing differently [FONT="]than its original designed. A piggyback intercepts the injection signal from the factory computer, modifies the signal and then outputs the modified signal to the injectors. The problem with all piggyback systems is that it never knows exactly what the factory system is doing. This is because the piggyback only has the factory computer's output as its input. The one exception to this is a boost sensor. In fact, the factor IAT (Intake Air Temp) sensor is disabled since the factory computer cannot comprehend the high air temperatures produced by super or turbo charging. The piggyback can only add or remove fuel based on boost. As anyone is aware who has ridden with a piggyback, is that they don't always run the same from day to day, location to location and sled to sled. The piggyback simply doesn't have enough data (or sensors of its own) to make accurate decisions. Take any piggyback on the market, tune it in a specific location then move to a different location (something 5000 feet higher or lower) and it will not run correctly without tweaking.
[/FONT]
[FONT="]
[/FONT]
Our standalone thinks for itself. It is a full featured computer and actually has more sensors than the factory computer. We include a MAP (Manifold Air Pressure, or Boost) sensor, BARO (BAROmetric pressure) sensor, IAT (Intake Air Temp) sensor and ECT (Engine Coolant Temp) sensor. We share the output from the factory TPS (Throttle Position Sensor)[FONT="] and the factory Crank Position sensor. There are no buttons to press and no knobs to tune. Its done. The system runs in a semi-closed look environment as a speed density system. This is the control systems used on all high performance high boost vehicles from cars and boats to motorcycles and aircraft.
[/FONT]
[FONT="]
[/FONT]
FEATURES:
- Includes a matched set of flow tested 750cc injectors (72#) (factory 330 nytro and 390 apex).
- Includes Plug and Play wiring harness, which means no wiring to install.
- Includes 3 bar MAP sensor, Baro sensor, IAT sensor & ECT sensor.
- ECU (Electronic Control Unit) in Billet Case and potted for weather and vibration resistance.
- Mounting brackets for ECU and Pressure Sensors.
- Harness is upgradable for future Ignition Control.
- Harness has direct connection output for our ProLogger Gauge (Tach, MAP and AFR)
- Note, if ECU is used with the ProLogger, the ECU is aware of AFR (Air:Fuel Reading).
If it has a Barometric Pressure sensor in it, then WHY wouldn't it be fully altitude compensating???
