Which Adjustable Fuel regulator is the best
I want to buy an Adjustable Fuel regulator for my 2008 M1000. I’ve been looking at Bikeman, BDX and AMP. Which is the best? Which is the easiest to install and adjust? Also does CAT or some else (D&D) make a regulator I can just change out my stock regulator to increase the pressure slightly (5 PSI more)?
I think I have run them all and the Cutler Performance regulator is, in my opinion, the best. Mounts securely. Good quality fittings, small analog gauge that works really nicely.
I just wanted to add fuel so I built my own for $27.00, but I can't take away fuel.
I've seen the bikerman and cutler used, both worked with no problems.
use the stock regulator, remove the rivets build a braket that bolts in place with a adjustable screw that runs through it and into the hole in the regulator and apply a little pressure to the baffle. then add a inline t and fuel pressure gauge. If you don't have good mechanical common sense don't do this or you may screw up your pump and be spending a lot more money.
