When is the Quiet Can for the silber turbo coming out?
CO 2.0
Corey told me it would be February. Well that has long passed, and still no word. I asked him a couple months ago and didn't get a reply. Anyone else heard anything yet?
Its out! You can order one on the website and it will be delivered in the fall. The boys are building a bigger shop at the moment - cranking kits (and parts) out through the rest of summer
You'll definitely like it too. You can hear the turbo way better and your riding buddy's ears will be thanking you haha.
Know that this post is a bit aged,- but as a dealer for Silber, I was just informed that a run on the quiet can is scheduled for the 2nd week in August.
FWIW
Yeah just got mine on a few minutes ago. Had to loosen all the other turbo to pipe connections, and pull the pipe to turbo springs to get everything lined up straight again. Definitely more quiet through the entire rpm range. Only downfall is the muff pot has to go back on the pipe after the Y-pipe.
Yeah just got mine on a few minutes ago. Had to loosen all the other turbo to pipe connections to get everything lined up straight again. Definitely more quiet through the entire rpm range. Only downfall is the muff pot has to go back on the pipe after the Y-pipe.
Does yours have the 'honey comb' mesh at the bottom of the fat part of the can?
Do you have to take the hood off to get to the muff pot on the pipe?
Hopefully the oem base plate will work, never tried it in that spot. I make my own steel base plates cause I crack the oem ones so much.
Needed for sure. I melted a hole in the upper part of the coolant bottle right below stock heat tape area last ride of the season. 4ft of fresh heavy spring snow at 9k ft. Super rare long turbo pinned ride in for 10-15 min straight. Blew a belt at the same time. But piping was just too close to the coolant bottle for the heat that day.
Yeah she got hot- I see your spring change cup is a toasty gold too- looks good though!. By using the quiet can ya re-routing the line line like CO 2.0 did is a must..
