The general theory seems to be that side loading or overloading is killing the bearings but are we sure?
Yesterday I took a peek in my 2010 M8 800 miles. The 6203 outer seal and cage were shot but the bearing still seemed to turn rather freely. This seems to be consistent with most of the other reports. Nobody suspected a bearing problem till they pulled it apart and looked.
Cat and a lot of dealers are claiming no knowledge of bearing problems, maybe because people are fixing themselves OR maybe because the sleds don't have enough miles where the bearing has totally failed, thus most owners are not aware there is a problem.
Could it be a lubrication issue? Maybe the sealed bearings are beginning to fail because of lack of lube, then, once the bearing begins to fail it takes out the cage which knocks out the seal, then that allows some DD lube to enter and then the bearing continues to work for hundreds or thousands more miles before total failure because it is finally getting oil lube from the DD oil??
Could it be a speed rating issue in that the bearing is turning faster than it is rated?
