I opened two of my friends DD. One 09, whit aprox 2000 km, and one 2010 whit sligtly more km. The 09 bearing was in bad shape, and most of the bearing cage was found in bits and piecec in the case.
The 2010, whole bearing cage on bought sides was gone. And we coul just find 2 tiny bits in the case. Rest of it was eaten up by the sprockets. An magnetic pin in the oil gave the answer wher the steel was. Never seen such a big round piece of oil before
Two sprockets in the planetary was missing tooths, and there was alot of scratches and marks around in the case, and on the rest of the sprockets. I noticed cat has changed the shim befind the bearing from 7mm in 09, to 6mm in 2010.
These 2 sleds has offcoures two different drivers. The 2010 model get alot more abuse of the driver then the 09 does. Jumps etc, and generally hard use.
Also our snowconditions over here are 80% hardpacked. That gives it even more abuse, then floating around in the powder all day.
My thoughts around it, is that the frame are flexing. Theres no way that the M frame is that strong that there won`t be flexing in it, and this bearing has to handle all the sideload in the DD. If the frame is flexing a mm or so during hard landing etc, it`s enough to take out this cute little bearing. Everyone been around the sport a while, know that regular chaincases have larger bearing on bought side of the drive shaft then the 6203 bearing.
So mu guess is, if you ride it hard, you will get trubble whit this bearing. Better change it before it snaps.
