Looks like there's contact from either the top or bottom rear track shock mounting points.
Mine has done the exact same thing. I'm not sure what it is.
Mine is a 22 khaos 165. It did it last year. My front track shock was blown out as well. I pulled the skid and checked everything out. I replaced all the bogey wheel bearings and got the shocks re built. I just assumed I ran something like a rock or stick through there and chunked the track. But seeing someone else's looking the same has me wondering if it's something else. I put e6000 on the chunked parts of the track and have been riding it ever since without any problems
Somewhere around 900 to 1000 miles. Stock shocks. It ripped the clicker adjusters off as well, so something was in thereHappen to remember about how many miles were on your sled at the time?
Stock shocks?
Bummer for sure... could've been ice, a stick, anything.
I just looked at mine and there's about a half inch of clearance between the top of the FTS and the window, so if that iced up and wore it could tear as you had happen.
Do you often ride in warm/slush conditions where ice builds up? Thaw in heated trailer/garage?
If nothing else, it's a great opportunity to get a 3" or 3.25" track.
Sounds like you might've just gotten unlucky with a chunk of ice or something.Did put 55 miles on Friday; this was the only time I was not able to thaw overnight and rode about 30 miles Saturday.
2 totally different types of damage on different sleds.
The sled referenced in the old thread has a center driver
Clips are now on paddles so the wear is much less between the clipped eyes.
Your damage on your 2024 is in the center of the track where the sliders don't touch.
Your 2024 doesn't have a center driver.
Scroll up 3 posts.Just a thought, Polaris changed track specs on the 2.75 series 6? Track for a year back in '22 or '23? Narrow driver's verses wider drivers, from memory. If a narrow drive track is used on a wide driver drive shaft or vice versa. It will only drive from the center extrovert part of the driver. As the center is unclipped, and the involute lugs aren't keeping it timed correctly. The extra force / wear will look like that shown in the original posters pics.
Yeah 2021 3.5 pitch 275 tracks were thinner belting and clipped between the lugs.I was referring to the original post and pics as I said in my narrative. I've been out of sledding due to family and job crap, but have read a bit about the changes / progression of chassis and changes. That nuance came to mind. That's all, if I'm wrong so be it, but I'd guess a lot of people out there don't even know about it, so figured it was worth a mention.
