Do I need to change the gearing or only de pitch, track and wheels ?
Gearing should be fine 7T x 2.86" pitch= 20"
7T x 3".00 pitch=21"
6T x 3.50"pitch=21"
The question mark is the rail length. IceAge lists both a 162/3 rail and a 165" rail. You should be able to "stretch" a 162/3 rail with an offset axle and larger rear wheel to take up an slack that may be present.
Do you have the part number? can't find it in the parts siteMine is on. 163 tunnel. 163 rails.
You don't need new rails, rail extension or off-set axle.
I already had 3.0 pitch Avid drivers, so my rails we already trimmed and anti-stab installed.
So other than that, just swap drivers and mount.
Plenty of tension adjustment left.
I'll get better pics, but this is the only one I have right now.View attachment 357472
165 has lots of tension adjustment left. No need for work on the rear end to fit this track.
He swapped drivers.did you put 6 tooth 3.5 drivers on as well or did you just keep the 7/3.0?
