i had a hard ski hit last year that sent me over the bars and i landed about 10 feet in front of the sled. i was side hilling/carving up through some trees and found a rock. i was probably moving about 10-15 mph and the sled came to a dead stop. it literally sheered off the lower a-arm and sway bar, bent the upper a arm, bent the shock, and wrecked the ski. i had the 2 bottom grip n rip braces installed and it didnt phase the S module or bulk head. i would like think the braces saved my rear end........but i cant prove it. i will say that i installed the braces on my new sled this year. they made a believer out of me.
There's no "GUARANTEED" answer, but without braces and with stock arms... a solid ski hit is almost a guaranteed big job.
With braces & Alt Impact arms (there's a rod end that can fail that costs $16 and takes 10 min to replace) an over the bars ski hit is no big deal & you just eat a snack while you swap out the rod end.
I've had two "holy crap, that's a total" kinda hits after making the swap... and both were fixed in a few minutes. The first one I didn't think to carry the spare rod end, and it sheared off damaging nothing else, the 2nd one I had it in my pack & swapped it out quick on the hill... nothing makes you smile more than a $500-1500+ hit... that costs you a part you already have in your pack.
I have alt impact arms on all my sleds now. I have yet to do anything to my doos but wiped a rod end off one of the pros. Didnt buy a spare but did after the fact. Dans a super guy and has great parts no doubt about it. I should do the braces but that sled doesnt see alot of ride time and i think just the rod ends do basically the same thing. Guess it cant hurt thoughYou're a good salesman! I copied several of your mods after reading your reviews and they have worked great, appreciate you sharing your experiences with these sleds. I really like these Alt Impact A-arms! I tried aluminum rod ends just for fun, they bend a little too easily (a decent jump would do it), but hit a rock and they shear off--10 minutes later you're riding again. I switched back to steel ends, found them on Ebay for $7 each shipped. Way better than $150+ for a stock A-arm (if you run braces) or more $$ if fully stock (not to mention you don't have to end that day). Plus these arms cut ~5lbs. I do run the lower G&R braces. Bent a stock arm last year with those and nothing seems too out of whack.
Read earlier in the thread someone did and it actual helped straiten things out. Won't be perfect but I'd prob fix first then install GNR. But it could be done without fixing firstCan you install even if yours is bent, but not to bad???
Another thing that most gloss over that I didn't think about till Skibreeze switched over a couple years back... WEAR BARS.
If you can get away without carbides, the sled will grab rocks way less, and slide over them instead. That's something that really is a significant difference imo. I won't have carbides on any of my sleds anymore, I use hardwelds on all of them. They do WAY better in the parking lot, WAY better having to cross over windblown ridges, and that same difference imo is apparent in smaller rock hits.
the best way to see what's bent. lay the sled on its side. 5 gal buckets under the handlebar and rear idler. from the rear, sight down the track and see if the front is centered. usually looks like the nose has been pushed to the side. you may need to pull the skid plate off to see it. the damage is typically at the lower rear a-arm mount... it gets bent/shoved to one side slightly.
Posted from Snowestonline.com App for Android
so what are you showing us here........the ball joins will sheer off before anything is bent?
