Whhhaaattss up Loui. Once he pulls the motor down to work on it the head will be off and timing done etc so it's the best time to put in the manual tensioner. The benefit to the manual tensioner is that you set the tension with the motor on the bench. At start up there is ZERO chance that you could skip a tooth. I have seen it 3 times and heard of it many other times happening with the stock hydraulic tensioner. The issue is with the TDC on the Nytro and where the cam lobes sit when the crank is at TDC. To be blunt, it is in a f**ked up position. Once you have the timing set with the crank at TDC, the timing chain on the intake cam sprocket, looks like it wants to come off (it is actually lifting up off the sprocket a little bit). I don't know this for sure but I think that is why Yamaha puts the timing chain guard stopper on the roof of the valve cover as a way to hold the chain down while the motor is started. I have done 5 of these my self and no matter what you do you cannot get that timing chain to sit tight over the sprockets. The hydraulic tensioner works by the oil running through it. That in itself is a problem. That crank is gonna be spinning over multiple times before oil even gets to the tensioner to release it to tighten down all the way. The way the stock tensioner initially releases is by turning the crank over by hand. It will release and tighten but not all the way. You can actually have a buddy turn the crank over and you can put your ear up to the motor where the tensioner is and you can hear it releasing. Problem is that it does not fully release and tighten until the motor is started. You can avoid all these issues by just putting in the manual tensioner. Most of the time the stock one will work but when it doesn't it will cost you mega bucks to rebuild that motor. At a minimum your valves are toast, if it jappens at high rpms your head could be killed and worse yet your rod bearings go and you lose a case because your rod poked out the block. Cheap insurance boys.
