Why did Polaris have such loose specs (pistons) in the first place? Even after the last update. Make no sense that a major corp. would make such a mistake.
I wish Polaris would have stepped up and covered this for you. This was a recall situation from the start. They should have just returned all these sleds. I have no doubt it would have cost the company less and retained more customers. Instead they just keep sweeping everyone under the carpet. In crappy economic times our government keeps pushing us to support American companies. Yet, this is how American companies treat their customers. No thanks.
That's the best explanation I've heard. Thank you"Ok the problem started with early 800 motors sticking pistons due to the very lightweight cylinder they were using, motor got a tad hot and the cylinder distorts (as much as .014 that I have measured) this causes a piston with .004 clearance to stick. So rather than re tool the entire engine for better cylinder (would require epa again) they loosened up the piston so it would not stick. OK, now the piston is flopping around like a fish as it has .009 to god knows what and with the high compression/fueling ect ect it now scuffs and or breaks off its skirt and the cylinder. so round 3 reduces compression and changes fueling (again) and still has even worse problems uhg. Now for 2010 they try to beef up cylinder skirt a bit and hope problem goes away as new motor is coming out.
The entire thing is a horrible example of trying to put bandaids on a known problem and hope it goes away.
I'm sure there are many more things involved with the epa,fuel mapping, metals used ect ect but its just a brief deal of what happened..IMHO"
