How much do you guys weigh?looked mine over no bending yet.
210 with no gear.
I like the idea of installing Better Boards. But, what will happen if my stock boards will start fall apart when using Better Boards?
Some pictures of the boards in the first post:
Now that the PRO's are getting miles and time on them we are hearing of some similar situations here in the states as well. KNOW THIS: THERE IS ABSOLUTELY A BREAK AND OR BEND FAILURE RATE OF THAT METAL. It's the known problem with such a thin sheet of alloy and pressures put on those locations. WE KNEW THIS RIGHT FROM THE START AND I'VE PREACHED IT UNTIL I'M SICK OF SAYING IT. By manufacturing and installing over 10,000 sets of Snowmobile Better Boards we have learned this important lesson. The metal you chose, the process you use for manufacturing, the finishes that you incorporate, and finally the DESIGN are all absolutely critical in the quality of this product.
So far we have over 300 verified installs of JUST the PRO boards and not one single reported use failure. (non crash related) All on our standard thickness. We have two additional thickness' available as well but so far have not seen that need on the PRO. The actual bar supports are failing faster then our cleated board inserts. You guys can have your choice of several home brewed deals making this concept/product but only ONE OF US HAS THIS EXPERIENCE AND THIS TESTED AND PROVEN RESULT. There absolutely is a difference and the best is clearly Snowmobile Better Boards. Gang I have studied all of the designs that guys are offering you and I have 100% confidence that our product for this application is proven to be second to none. NONE! The highest performance with NO RISK to you or your machine. Remember the statement "you get what you pay for"? This one really applies here!
Are there any confirmations of this happening to any sleds in US? How many sleds total have had this issue now?
Can you confirm when your build date was? Maybe we can try issolate this down to material defficeny or a bad lot of stressed material. It also looks like it could be issue with the material thinning out to much due to there stampling process
The running boards don't just magically break. They break or disform from a specific amount of applied pressure associated to use. The legal question here in the states is "normal use". Unfortunately this is a situation of design but we as consumers are only protected if it's deemed dangerous or if Polaris determines that the design is inadequate enough to have a risk either legally or conceptually. On the otherside of that statement is the fact that I am also a manufacturer required by law to deal with the same circumstances should they occur. IE you are not protected by warranty because there is almost no way to determine if this is a normal use situation. You may get resolution but only if the warranteer decides it's better to pay up and repair then suffer the potential negative consumer opinion.
Check Cr Racings new wide board kit, with tunnel bracket. Won't bend this boards. 2 hour install.
I was only naming the Swedish Canucks....left out Lidstrom and Zetterberg too
there is a tear completely through one of my cleats on my right side board, some of them are starting to fold. I don't have a picture of it, I didn't even notice it until it was pointed out to me by my buddy who works for my dealer was out checkin my sled out last sunday. Not real sure how I'm gonna fix it as I have already installed the polaris board supports.....I dont really wanna take those off and put better boards in. I think I can patch it up well enough for the couple months that I'll have it yet....
Please take some photos, Polaris is still telling me that Im the only one in the world with this problem...
Don't make this out to be a big problem. Very, very few have issues. This guy from Sweden is posting all over the world about this. Kind of ridiculous IMHO. If you jump hard enough often enough you will bend any board. I'm not saying Polaris shouldn't beef it up a bit, but this is not an epidemic.
Whoever started this post isn't even having a problem. Why read something you cannot confirm is true and post it here? You have no idea how this happened.
