So to fix the problem, I just have to replace cap, v/r and ecu with the 2010 parts?
I don't think there is a 100% fix. The updated VR is supposed to be beefed up quite a bit more than the 08 model though. I don't think they have a full grasp on what is causing the failure at this point. Electro Tech had stated in another thread that it is a good idea to check the wires in the taillight and hand warmers as they are prone to grounding which may contribute. When I got my sled in 08 I did quite a bit of rerouting of cables anyway. Quite a bit of stuff looked prone to rubbing and grounding around the steering stem. Tape off any exposed connectors. I spent some time zip tying and routing wires around the voltage reg as well ensuring it could get the most air possible. Cut the foam pad between the electronic shelf and clutch guard so so air can flow through the pre existing whole.
Those of you having multiple failures I would push Polaris to replace the entire harness. Could potentially save some headaches and save them more $ in warranty. Just a thought
