E
ericbigbore
Cutting issues
After 250 mi the cutting stopped on my buddys sled?
Fixed the wire to the oil sensor-no luck. Unplugged the gauges-no luck. Unplugged the hand warmer connectors-no luck. Unplugged the DET-no luck. Good idea, Freak--when the DET is unplugged do I need to close the loop (like the Edge temp sensor)? Anyway, it is still cutting out. Feel like a sensor is telling the puter to do this.
The idea of the clutching being wrong could actually be correct. Polaris in an attempt to increase fuel economy and emissions. Defuels the engine or even cuts off fuel on de accell. The ecu decides what de accell is. Running to light of wieghts can fool the ecu into thinking you are de accellerating at times when you would think you are not. Right around 6000 rpm is when the ex valves want to start opening. This throws another change that is happening at that time. Some guys are running the 11 series wieghts and less pri spring and none of these guys have had any cutting out issues. Cutting out becuase of snowinjestion is another problem all together.
My sled was also doing this cutting out. Sled would pull hard sometimes then go into a limp mode at 6400 RPM. It also seemed to have a limp mode just of engagement RPM. Once you burped the throttle a couple of times, and away it went again. Took it back to Dealer and a Crank Position Code was up. The stator tested OK, but that does not mean that it is OK all the time. They have ordered a new stator and if it happens again it will be changed.and are waiting for new ones. Polaris does not make rail stiffiners but BRP (Skidoo) does and they bolt right on, with a couple of holes drilled. Just an idea if any one beats there sled like I do.I have not had a chance to ride it again because I did a jump and bent the rails
