Twisted Turbo Thread Only-Good Idea?
Can someone tell me what the yellow blue mod on the box is . Is it on the boost cycle or is it on main jet cycle thanks Jim
If you have the Attitude box that came with your kit from Twisted, the yellow/blue should control the switch point as to when the yellow mod kicks in. Bigger numbers, yellow mod comes in sooner. The green/blue should control the amount of fuel added under boost.
Anyone have info regarding fuel mixture for TT RG M1000 07?
Please correct me if I am wrong
Max boost for 91 octane is 5-6 lbs?
Max Boost 100 10-12lbs?
Max Boost 111 15-16?
Safe A/F 12?
Anyone have numbers for this set-up
1/3 91 and 2/3 111 Max Boost?
50/50 with 91 and 111 Max Boost?
Thanks for any new info or correcting the other suggested info?
send me a PM if you want to join a twisted kit related Private forum....only twisted related topics and information gets posted in this private forum, nothing about general stuff...thats what this forum AC-Turbo forum is for:face-icon-small-win
I'm running a RG Twisted Turbo on a 2009 M8. My Peak RPM is 300-400 higher than it should be. My question is, how much adjustment on the Black Diamond Extreme clutch is needed to bring the RPMs down?
not every clutch and boost combo is the same...generally removing a gram will give me 150more RPM, but these cat sled really fall off at higher elevation
you need to add weight, dont screw with the primary spring, i have not had good results with the primary spring, leaving her at 170-310 or whatever it is
