H
hatchers
I don't doubt for a second that they run very well. ccpowder has been on here long enough that if he says it runs good that is good enough for me.
However, while I am sure it does perform well, I don't believe the 250 hp at 5lbs of boost on pump gas for one second. I don't care what size of garrett is on it. Those #s aren't accurate.
numbers..shumbers, i dont ride a dyno, i ride snow, its way more fun
so you dont care what size the compressor is?...volume is a much larger factor in respect to flow then DP ratio, but you need to do other stuff as lower RPMs in a larger void wont build pressure until later in the RPM range, i read a book about this stuff one time
So 5psi of DP is a direct unit of measurement in a HP fomula?...please explain
