powder_rider
hey i have an m7 and i was wanting to do either a turbo or supercharger and wanted to know what works the best
There is no reason why a supercharger wouldn't work on a 2-stroke, but I haven't heard of anyone who has one.
If you SC a 2s, your only pressurizing the intake not the exhaust, with a turbo you will have drivepressure/backpressure in the pipe which in a 2s needs to be somewhat balanced for them to make power.
There was a guy a while back that had SC a TCat or big cat tripple but it had all kinds of vavles and extras in the pipe to create backpressure. Ended up working but not very economical or user friendly!
A supercharger is just an air compressor that runs off of a pully off of the crankshaft of the motor. It forces more air into the intake which allows you to add more fuel and thus more power. That same air going into the motor comes back out in the exhaust thru the expansion chamber of the pipe, creating the exhaust back pressure, only with more volume because there is more air going thru the motor. I'm no expert but I would think it would work just fine without having to modify the pipe or changing exhaust back pressure. If you have more air going in the motor (more pressure) you will have more air going out of the motor (more pressure). I would say they would be proportionately equal.
I personally feel that a supercharger will work awesome on a twostroke because I feel that the only reason boost works at all on a twostroke is because you are actually pressurizing the crankcase rather than the cylinder itself. With pressure in the case, more mixture is forced into the cylinder when the transfers open. I feel that a turbo works this way and that a supercharger will work the same. I have a supercharger ordered and plan to verify my theory.
I think that the supercharger is far superior to a turbo on a two stroke because of the greatly reduced charge temperature and the anti lag affect.
