Here is my 2 cents.
Lowering the compression WILL make it less sensitve to detonation. AND... it will also make the engine deliver less power and torque at low RPM's... lower speeds threading thru the trees.... It will have less low end grunt...
In the cost and benefit analysis of a low compression head....one of the benefits are that you can run more boost for a given octane fuel, one of the costs is less power until the turbo can make effective boost (low rpm torque will be compromised).
This is a balancing act… there is no “free lunch” here.
Until you make effective boost, the engine will, for all intents and purposes, be naturally aspirated and drawing thru a restrictive intake (thru the compressor wheel, the charge tube, elbows and airbox)... low comp engines don't make as good of a "boondocker" as normal compression engine. Weather that is turbo or naturally aspirated.
If someone sells you a kit for pump gas to run at your elevation and tells you that you will be able to run that "pump" gas at your elevation... get a written guarantee on that... If it works well... great, you will be the best spokesman they could have for low altitude sales... if it doesn't, then you are not on the hook for thousands of dollars.
Rob heeb (f-bomb) runs a 860 i think with GREAT satisfaction.
Rob’s personal sled last season, I believe, was a stock bore 800CFi on twin pipes...not sure on the porting... He was super happy with it from what he told me. His sled has also benefited from great suspension setup AND a systematic approach to making the sled better overall. He has also ridden ALL of Carls packages from mild to wild... he would be a great person to ask in a PM what his opinions were. He has also ridden quite a few of the turbo packages out there...
You are in a unique position that you have good, oxygen rich air for your sled and don’t lose the kind of power that people at elevation do. This is a "luxury" that most mountain riders just don't have...oxygen rich air.
No matter how you look at it, there are no setups that can go from 1000 ft to high altitude (8000+) without adjusting things and spending time to get it dialed in.
IMO... at your elevation, the Big Bore is your best choice for pump-gas solid boondocking performance. It is not the power "numbers" but how the power is made and comes to play in your riding.
I'd call Carls, talk to Chris Kasel in the performance department about the big bore... He will give you the straight answers and not try to sell you something that will not fit your needs. I'm not sure that THEY have a setup for your altitude... but definately better to get the info directly from them.
Silber, those numbers seem a bit off to me (octane, altitude etc). Are you sure that you got them right?
You seem to be saying that you are running low quality, 91 or less octane gas from a farm storage tank (which might indicate water content)…. At 7.5 lbs boost at your elevation with a low compression head and it is performing well with no deto?
The simplest way is to lower your compression, than add the turbo kit of choice. This will allow you to run 7-8 psi at sea level, than at your 5-8000ft you could run 10-12 psi on pump gas 91+ octane.
10-12 lbs on 91 ("pump gas") octane, even with a cut head, at elevation, either sounds like a recipe for disaster or you would have to cut out so much compression out that it will be a dog at lower RPM. The same for the 7-8 psi at lower elevations. I am familiar with turbo setups out there today as well as lower comp heads. The 700, with its shorter stroke, even more so than the 800.
Last point… all the power in the world won’t do you any good unless your suspension, front & rear, are quality setups.
Whatever you get...do some
more research... ponder it for a few more days and then make up your mind. And good luck in whatever you choose... keep us posted.
