If you put it that way no thats not too bad. On my 08 put 2000 miles on last yr. and it cost me zero but there is the lack of horse power that might be usefull. my other thought is here where i ride very little with out tress and i mean very little, so im not conviced that it would be worth the extra?
thank you great imput.
Outran to 1000 feetmaybe...But after that
the turbo blew by at atleast 25mph higher speed....
I dont know...but that 860 must be a monster
When racing non turbos last year
Normally when you had braked down to
zero in the end of the field/Lake/Hill and turned the sled back they would pass/Struggle up ....
BD Race Turbo D8
welcome to the turbo revolution.....![]()
Here I thought this thread was going to be about a fat broad on a D8...![]()
I wasn't on either of those two sleds during random heads up testing but I was running other sleds along beside (I say along side but what I really mean is that we started along side and I was back about 10 lengths!) and you could see that the turbo had more legs. The 860 would be ahead to about 800-1000 ft and then the turbo would leg it on by. Really hard slickery snow and none of those sleds really hooked up that great on the leave. (for example my 660 which hooks really good and gets with the program whooped up on all three 600, 700, and 800 turbos in a very short drag race 400-500 ft but at somewhere between 400 and 500 feet the 800 turbo went by me at over 20mph! The 6 couldn't run with me no matter how far and the 700 was closing but not like that 8T. Anthony Oberti was on all the turbos I was on 10X 660 and he can verify) I will also say that the twin pipe 860 didn't quite have the same giddiup as it did when we had it in Bend last weekend but it is still OUTSTANDING.
This particular turbo setup ran and felt like our Aerocharged 700 turbos but at 11 to 12 boost except this was at 7.5lbs. Also the setup was much more linear and smooth. The T8 felt good fast and smooth up a short relatively steep 800ft hill. Very very similar to how the 860 and 840s felt on the same hill. Didn't run them side by side up that hill for comparison so we just have the seat of the pants to go from. Very close all awesome!
Here is a breakdown of speed as I saw it with hard pan gradual hill drag racing...lots depending on starts and lots of variables. IE you could win a drag race on anyone of four setups depending on the run. All of the fast 3-4 were pretty darn close for this limited test.
0-1000ft
from fastest down
1140 Carl's
860 twin piped black sled
or tie with
800 Boondockers turbo (at 800 to 1000ft the turbo goes by)
800 twin pipe ported race gas
840 single tie 860 single (back and forth but darn near the same)
yup, because that is what is the funnest part of sledding and what we all like to do the best... run up and down an open field. yee haw! not to be too big of an a-hole but really, with the exception of a long drag race (most competitions are 660 feet) and open hill high marking, when do you ever hold the throttle wfo more than a 1000'? yes the turbos make unbelievable power and can climb almost anything. i ride with a guy with a $35k+ 340hp apex that is crazy sick, but really just not for me. if an 860 will pull a turbo dragon up to 1000', i'll take the 860 any day and i know, over all, i'd have more fun on the 860. but maybe that's because i don't have one... that, i no longer need to have the biggest d!ck on the hill. good luck and enjoy whatever you decide to do. are turbos a revolution or a fad?
pv
