M
mynewuseddoo
go 8" across the clutch where you would get the 1:1, if you take 8" and multiply it by 3.14 you get 25.12". So if you stuck a 8" wheel and turned it one revolution it would travel 25.12" then multiply that by 8000 =200960" a min. divide it by 12 to convert to feet =16746.666666 divided by 5280' =3.171717 multiply by 60 to get from min. to hrs = 190.303mph. Then take a 1:1 of 80mph divide 190.303mph divided by 80mph = 2.378788 for a ratio. (the first time I did it I was off on the mile and had 5260' when I should have had 5280')
But this is a ratio if you have 8" drivers, if you factor in the height of the track then the height of the lug it can really change. this is a ratio if you only count the driver size. So if you take the 2.378788 gear up then the 2.24 gear down at 8000 rpm and 60/60 gears in a 1:1, then subtract the two and you get = .138788 then multiply it by 80 =11.10 and because its a gear up you add it to 80 to get 91.10mph 57/63 gears 82.42mph 55/65 = 77.08mph
I could be way off on this but its making sense to me.
So then if I am only able to pull 48 MPH it does make sense to gear down in order to bring my clutches closer to the target 1:1 ratio with the available power I have in my sled. As per the calculations, there is no way I can be at 1:1 at 48 MPH with 57/63 gears in my DD, correct?
