WYo, I wonder how much of the difference you mention in speed is due to the 90 duro on the HCR compared to the 80 on your 1000?
BTW, I have asked the MOD to move this other info to another thread to clean this one up, so if it moves don't be suprised. We can continue over there.
The other thread.
http://www.snowestonline.com/forum/showthread.php?p=2607917#post2607917
First off no one has verified what a 1:1 is, we have to know every gear ratio throughout the drive train. then factor the gears in. What I have stated was hypothetical. JeffK you say on 6lbs your getting 55mph, everyone else in that range says 40-50, thats to big of increase to compare so either conditions where different or something. Please explain. Do you pack extra weight like gas or what ever and what is your weight.
In our case, Driver Diameter = 8 x 3.0 / 3.14 = 7.64"
That doesn't make any sense
The best I can come up with is the sled is geared up in the clutches by 2.4 then dropped in the planitary 2.24 so there is still a gear up of .16 , with 60/60 gears. Thus 8000 rpm in a 1:1 with 60/60 = 92.8mph. 57/63 = 84.4mph. Now that just doesn't seem right. Thinking its going to be easier to put on a stand, mark the clutches and check for a 1:1 and see what the speedo says??? Personally I think gears can effect backshift but overall track speed can be accomplished with clutching no matter the gears.
Thats what everyone assumes, but I think it is off. Like I was saying weather you factor the gear up in the clutch or the driver it goes up 2.4 then down 2.24 in the planetary.
Jeff you ever come up to cooke, I would like to see that sled run. It sound impressive.
