Guy's for starter the 433 weigh's 1 gram more than the 414 which when you multiply that times 3 ramps will add 3 grams of weight to the XP, LOL.
I prefer the 414 because it's slightly steeper in the critical part of the shift pattern as can be seen in the photo as apposed to the slightly flatter 433 in the same critical shifting area. Yes coming out of the hole is important, however not as critical or important as maintaining full shift and rpm under deep snow hill climbing and deep snow boondocking conditions. For deep snow riding the TRA prefers a slightly steeper finish so the arms continues to have to push and work aggresively as it has to quickly adjust to the ever changing loads of deep snow just to acheive full shift and hold rpm. The flatter 433 doesn't provide imo enough push for the arm, unless you click to clicker 4 which forces the arm to push more aggresivly on the ramp which will put more side pressure on the sheave/belt in order to maintain peak rpm..
![0011-5.jpg](http://i240.photobucket.com/albums/ff99/craftwoodhomes/0011-5.jpg)
