TRA Clutch Question
2003 should be a splined shaft, the 2008 should be a taper fit. No it won't fit.
I swear my nephew told me a buddy tried it when the 07 clutching issues were new, and it didn't fit, my bad!!!
As hymark said, the splines are internal on the tra where the gov. cup slides onto the fixed sheave, the taper is on the back side of the fixed sheave that slides onto the crank.
Don't know if the 07 pto taper is same as 03, I know they changed the sheave angle in the past, that may be where you run into prblems??
