SLY
What boost/fuel/AF were you runnin? I run Carillos and JEs up to 20-25 lbs on 110, no problems.
I'm surprised you can keep the head gasket sealed
I'm surprised you can keep the head gasket sealedWith high strength head bolts I had air getting past the gasket into the cooling system in the low to mid 20 range when my controller screwed up.
u can run 20psi on the stock nytro but u need the propper box one that adds fuel and allows u to pull and add timing that is why ur fuel is so crucial to compensate for the pre ign.(DET) but if u can pull the timing back and add fuel u can actually run premium. aka Rapid Bike 3
p.s Don't understand, too bad, enjoy rebuilding motors...
i personally would not run pump fuel good gas is cheap insurance. my point is that u can't just put rods and pistons in a motor and expect to make more power with more boost. it will actually make the same or less. boost is compression.
yes u can run high boost on pump fuel 15psi sea level timing pulled 20 psi at 7500ft timing pulled but a nytro at 15psi no timing pulled at 7500 on straight av gas pulled way harder. and in my opinion would last the longest.
ps.sorry didn't mean to be snide
pps if ur turbo manufacturer says run a max of 15psi run it don't try and push it.. And try and enjoy the rest of the year sledding rules!!!!!
Not just doing rods & pistons, and valve springs. I was just simply looking for some feedback. I have orderd everything from dustin to safely run 15-20 lbs of boost @ 7k-10 on straight race.
BTW what controller would you suggest running??? I have the BD Box. And BD Injectors.....Or a BD Kit if you will.
Yup, I agree. With headshim and 35 lb ft tourque the limit seems to be about 17-18 lbs before air starts to displace the coolant.I'm surprised you can keep the head gasket sealedWith high strength head bolts I had air getting past the gasket into the cooling system in the low to mid 20 range when my controller screwed up.
Apex or Nytro? The Apexes don't seem to have the same problem. It is also the long hard pulls at WOT 20-40 sec.FWIW I have been running 20 psi @ 3-6k ft. Have all season. 38 ftlbs rings a bell when I did my head shim. No coolant loss at all. Straight c-12 for fuel. The whole system has been aheckova lot harder to keep sealed vs 15/18 lbs, but the head has never pushed coolant.
Ya its an apex. Wonder why the nytro's are having trouble... At 20 lbs there are not very many 40 sec pulls with the snow we have had this year![]()
I'd sell the BD kit and get Impulse race kitThen you could run the pure logic box, which is simple to use.
