First, You and Allen are friends so it is only right you should try and be his wing man and defend his products and choices. After all, either he named it for you or you got the nickname / moniker from him (Yes, I read that here too).
I've read plenty on of posts on the lack of durability inherent to the TS drive train; Specifically the shafts and bearings which are a result of torsional flex and a general lack of stiffness in the entire assembly. I do not save or bookmark everything I read so I can defend my opinion of the item in question. And even if I did; with SnoWest what it is, and their protectionism for certain preferred vendors the bad press / reviews would quite likely be irradiated prior to times like this.
When both the shafts, the key / keyway are twisted and rolled and next to impossible to remove / replace without cutting them in multiple pieces to remove (from posts I've read), that indicates to me that the shafts are too soft and should have been heat treated and that they should have been machined to tighter tolerances so the key does not roll in the keyway. My guess is the key is too short and the sprocket is also too narrow to live in that application from the reports of that occurring. When the single bearing setup is getting wiped out and they just throw a double bearing setup at it. In lieu of spending some money to increase the quality / stiffness of the shafts and the mounting points; that is a bandaid approach, as I've previously stated.
I don't own a bike nor any of the "kits" for them for one simple reason; the biggest attraction for a snow bike kit manufacture is to use an existing platform that already meets emissions requirements, so they don't have to invest any real expense into their "kit". That is also the largest draw back to them all, IMO as well, because the balance / performance will never be correct with a bike designed to be balanced on wheels.
My opinions are solely based on sound engineering principals and 35+ years working in the mechanical arena for a living, and having to fix stupid ill conceived designs to insure 99-100 percent reliability for the corporations I've been employed by.
My biggest fear is not the initial cost of the Yeti... It is when you tank the tunnel on a rock and have to replace the tunnel.... I would think...... it will be pretty damn pricey... Already done this once on the timbersled and it came out to close to 500 which was expensive enough for me....
Sent from my iPad using Tapatalk HD
