M
mtn-doo
Going to install the 38MM Billet Smart Carb. Before the carb goes on, I am going to install the carb heat collar. I put the carb in the freezer for 6 hours. Next I prepped the collar by removing the plug and both barbed fittings. I lay the heat collar flat on top of a bench vise. With a butane torch I gently heat the outer corners of the heat collar until just "hot to the touch". Heating the outer edges pulls the inner radius outward a few thousandths. I then take the carb out of the freezer and lay it flat on the bench. With leather gloves, I index the collar in the position I want without touching the carb. Just hovering over it. When my alignment is where I want it, I push the collar into place and let everything cool for a few minutes.
The carb install is super easy. The one thing to remember is to pull the choke knob up before you turn your gas on. The carb is sealed and needs to vent the air out of the float bowl through the choke circuit as it fills.
