One thing i have noticed over the years with the YTZ7S batts in the 300 is i never have starter issues like all my friends do with the stock 4 or 5 battery. Not sure if its coincidence or not. They crank faster and don't seem to put as much strain on the starter. Take it for what its worth.
I have the YTZ7S in my 300 and the bike still goes through starters like air filters. I've given up completely on the 300 starting system. It's simply a horrible design.
Do you think with the smart carb this is something that is needed if it is in the budget?The Ceramic work by SLP is super nice. The polished silver color looks just like a sled pipe from SLP. The corrosion protection as well as a little thermo protection will be a nice plus.
Be sure to weld in the bung prior to sending it off for Ceramic coating. The bung and welds are all coated and look OEM. No weathered welds from heat and moisture. The location of the "fast response probe" is placed at 4" from the pistin skirt. That is about 1/2" less than usual. The flame tip will be a little shorter in this pipe due to the quick 90 degree turn. The depth of the probe is also important. You want it as close to center as you can get it. If you look at the tip inside the pipe, then look left down the tube of the pipe and weld line, you will have an aid in placing the depth correctly. The third thing to remember with probe placement is the "loop" on the tip needs to be in line with the exhaust flow, not perpendicular, for an accurate reading. The elbow of the upper portion of the probe will be 90 degrees from the center-line of the pipe.
This is not mandatory but I rely on mine heavily when tuning and testing. Always confirm your temps with a plug inspection. A set my alarm at 1270F and shoot for a sustained , long, WOT temp of 1190F to 1230F. Confirmation in your plug will be a medium "tan" to "caramel" color. Chocolate brown and darker is too cold/lean. Anything lighter than "tan" is getting too hot/lean.
Parts are showing up. The cylinder work is super nice. Nothing crazy, just a clean up and the exhaust side opened up a little by Eric Gorr of Forward Motion.
What year is your 300 ? How many hours on that 300. Curious
Isn't the probe placement 6" from piston skirt
Because 4" would be in front of spring hoops? Thanks
Ah, ha ha....got my parts, man Slavens is fast, ordered on Tues, got them Wed, I'm only 50miles away but damn thats fast. I have to do this build in stages as the cost of the parts is staggering! I have to recover/forget how much the last bill was before I can order more....and I have to order more, this IS the ULTIMATE 300 build and I'm following Randy's lead. Thanks Randy for all this info! No need to reinvent the wheel.
The Inquisition, let's begin...
EGT- my KOSO rapid just showed up, months before I can use it, 1250 WOT is where you wanna be, so are you just adjusting fuel/air ratio, richer cooler, leaner hotter basically? Im guessing that since EGT is an engine limitation, that its the the best you can get and does not change with altitude
Rekluse Clutch- can you tell me again the benefits of a $900 autoclutch on a snowbike, I saw before where you said 'you don't need it but', can you give some instances of the benefits. I may have answered my own question this week when i came upon a nasty rock section and in trying to clutch and push the bike up over the rock an autoclutch woulda been the perfect tool.
Smartcarb- in Colorado we ride from 9000-12000, so jetting should cover that, but I'd read were you were pretty happy with the smartcarb adjusting for the accumulation of frost, ice, something on the air cleaner throughout the day.
This should be fun!
