The top end is off mine and was thinking about installing 2010 cylinders; but will have to split the case and bore it to fit the 2010 cylinders...Don't know if it is worth the effort or the $.
Either way the Fix Kit is going in after I make a decision on which cylinders to re-install...
akrevrider
Akrevider, I have been very happy with the kit from pms Polaris and with the a little higher compression head and the power commander has been the answer for me.
Will look to see if I can find one of the 2008/2009 pre-update heads with more compression than the Polaris updated head.
IMO if you were going to split the case and then have it bored you might as well buy a big bore kit from Carl's or SLP where the piston tolerance would be with in spec and you will obviously get more bang for the buck.
You should look close and reconsider the right repair kit from MTNTK sold at PMS Polaris it has made all the difference for my sled to run good, strong and more reliable. I have also heard there are some other kits now available from others but this kit is tried and proven. I brought my sled to PMS and had the kit installed and they are a class act.
The kit that I have is from MtnTk Dyno sold at PMS Polaris. Really looking forward to a season of riding without worrying about the skirt breaking off one of my stock pistons.
Good luck with your decision and what’s the hurry it is still the middle of summer.
Akrevider, I have been very happy with the kit from pms polaris and with the a little higher compression head and the power commander has been the answer for me.
Good luck with your decision and whats the hurry it is still the middle of summer.
akrevrider
Any body running a PCIII with this fix? What polaris map are you running and what map you running in the power commander? I am considering getting this kit as i have a 2008 800 dragon with slp single/can, power addiction 14:1 head running 20% 110 fuel, custom clutching and PCiiiusb w/ slp map. The guys at PMS Polaris said they do not recommend running a controll box as the original polaris 08 map is great, and they don't support any tunning for the power commander. But what about the lean mid range that caused so many problems? Thanks for any help.
ToeHead,
I have a map from Jim at DynoTech that was tweaked on the dyno at Bikeman Performance. Jim's PCV map was very good just a little too rich in a few spots and on the top of the rpm band. The orignal 08 Polaris map is pretty good just too rich and not every sled motor is created equal based on how loose the piston is in the jug.
I can tell you after PMS installed the fixx it kit with the 08 factory map the sled was way faster then ever before with the pipe and pcv. My sled has never ran so well and the dyno numbers showed a considerable increase with the 08 polaris map, orignal 08 head, and bikeman pipe.
I am sure PMS is afraid of the self tuners who do not have access to a dyno and will want more and will lean it out too much and then burn down the motor and blame it on their kit.
Earlier in this thread I posted my dyno numbers as well as on another thread that can be found on this 4m. I am not sure if the pcIII and PCV maps are interchangable or not? I suspect Jim at DynoTech or SLP can give you that answer. If you have any other questions just let me know.
Chris
Do you know why you "stuck" a piston? Just checking.Hey Guys, I have an 08 800 Dragon. Went thru 2 engines on Polarises dime. They finally put an 2010 complete engine in it at the end of the 2010 season after the crank broke. Well at the end of last season I stuck a piston. Im going to order the Fix hopefully to cure my problems. My question is where should I send the cylinders to get redone to match up with the new kit? Or would I be able to hone the cylinders even though the piston seized in the cylinder. And what does that usually cost to have done? Thanks for any input. Also how are he engines holding up in the Pro? I dont want to dump 12k into another pile of sh!t.
Stone
