I fouled NGK BPR9ES.
After I ran that tank and got the crazy oil mix out I went to The NGK iridiums. I'm mixing 1/2-3/4 ounces of injex to each gallon of gas.
On the break in tank it was easily over 1 ounce of injex to each gallon of fuel.
I'm now running about 20% VP110 leaded.
2009 163
Stock track
FIX kit
SLP pipe kit
19/42 gearing
PSpring Team Bright Green 150-340
SSpring stock Bl/Pu c/w 2 delrins
Helix 62/42/.40
67 gr Ron's Big Torque weights
PA 12.5 head
PCV SLP Map
SLP Intake kit
Holz Vents
Exit XO FShocks
Nextech FoxFloat Rear conversion kit
Holz Chaincase Drop kit
Thought I would give an update after this passed weekend. This is my third year with this machine. Have added "Stuff" each season, not all at once. I now have a little over 200 miles on the "FIX Kit". Readjusted belt clearance before last weekend and installed Ron's weights which were 1 gram heavier and have a modified profile. Since the piston update my RPM's have been high, 8500 peak and a hot secondary/belt. Machine worked the best it ever has yesterday. RPM's were back to where they need to be 8250 +/- 50, peak 8400. Cool clutches and belt. A little warm after a lot of boondocking and 2-3 pulls on the hill. Great base with 12-18" of fresh. 3000-5500'. Still a very small griggle in the mid-range. Will have work with the AutoTune now, I guess. I go 260 geared up and this setup pulled like a mule on the hills, back shifted the best ever. The "FIX" and PA head has really given this engine a much needed improvement in the power department. I think I can now just leave everything alone. Ride her till she breaks!!! LOL![]()
I just got my 09 switchback out last night for the first rip since I installed the fix. I am running the 167hp stoutner SLP pipe map with the ethanol wires plugged in. I'm running non ethanol 91 octane so it is pretty rich but I want to play safe at first. Will have a good look at my plugs and most likely unplug the ethanol wires. Power is better then I've ever seen from this sled so far.
I have the fix kit, power addiction head 12.5:1, slp full pipe, timbersled intake, pc3, ngk bpr9eix plugs.
Which Polaris flash are you running, and what are you using for fuel?
Is anyone running the fix with stock 09 head and latest flash? Just wondered if it would work and be a cheaper way to go then a aftermarket high compresion head. thanks
k thanks, You running dyno tech map? Hoping maybe ill be able to keep a mag side piston in it.this is what i'm running plus a pcv. my sleds runnin super strong and i feel like the compression is fine with the stock head.
