C
craigvansickle
ACCOUNT CLOSED
I am using stock 08 specs from my IQ service manual for the 600,700,800 rmk 155. All specs for 0-2000' The manual shows the all the sleds bellow have the same 56/42-.36 driven helix, the same 140/330 drive clutch spring, the same 3211115 belt, and the same 8250 operating rpm. The only thing that varies from sled to sled in regards to clutching is the drive clutch weights, driven clutch springs and the gearing.
600cfi rmk 155
125hp
Drive Clutch
Weights: 10-64
Spring: 140/330
Driven Clutch
Spring: 160/240
Helix: 56/42-.36
Gearing
19/41
700cfi rmk 155
140hp
Drive Clutch
Weights: 10-66
Spring: 140/330
Driven Clutch
Spring: 155/222
Helix: 56/42-.36
Gearing
20/41
800cfi dragon rmk 155
154hp
Drive Clutch
Weights: 10-68
Spring: 140/330
Driven Clutch
Spring: 160/240
Helix: 56/42-.36
Gearing
20/41
When you step from the 600 to 700 there is a 12%, 15hp gain. They 700 gains one tooth on top on the gearing. It also gets a softer secondary spring. It gets 2 more grams on the prim clutch weights. If I understand things correctly all of the changes above load the 700 engine with a little more track rpm at engine operating rpm than the 600 = better climbing. Not to mention the better engine response, but or now I am only talking about when all three engines are at there shared operating rpm of 8250
When you step from the 700 to 800 there is a 10%, 14hp gain. The gearing is unchanged. The 800 has the stiffer 160/240 secondary spring (same as 600) It receives another 2 grams of prim clutch weight. From what I understand the stiffer secondary spring would pull the belt more towards the driven clutch - reducing track speed. The added two grams in the weights would pull the belt more towards the drive clutch adding track speed.
Do I have things right so far?
600cfi rmk 155
125hp
Drive Clutch
Weights: 10-64
Spring: 140/330
Driven Clutch
Spring: 160/240
Helix: 56/42-.36
Gearing
19/41
700cfi rmk 155
140hp
Drive Clutch
Weights: 10-66
Spring: 140/330
Driven Clutch
Spring: 155/222
Helix: 56/42-.36
Gearing
20/41
154hp
Drive Clutch
Weights: 10-68
Spring: 140/330
Driven Clutch
Spring: 160/240
Helix: 56/42-.36
Gearing
20/41
