moving the scratchers to the skis is the most effective.
Sent from my iPhone using Tapatalk Pro
You don't need the stand off block - just slip end inside rail cut out ....I’m only aware of the Ice storm OTTP slightly outperforming the HOLZ scratchers. (Polaris copied / bought out HOLZ for the rear suspension geometry and scratchers)
The oem poo scratchers are around 2x stiffer than staycool or other aftermarket cheap scratchers.
The doo coil spring scratchers chintzy cast aluminum rail block just shatter and fall off quickly. (Besides the fact they throw up less than half the snow of polaris scratchers)
Sent from my motorola edge plus using Tapatalk
The oem ski dampeners make the oem scratchers look really good. Polaris has some work to do.With all the great improvements for 2022, why are the same substandard ice scratchers being used on the new sleds?
Polaris really should have ice scratchers that are reverse capable and that actually do a good good of cooling.
How are you breaking the rail mount??? Have them on a couple of Ayxs and Summits and gave only seen the stand offs break ...I’m talking about the actual mount that holds the coil on the rail.
Never happened in our group in the years we've used them. Those Doo scratchers have been great for us.The cast aluminum shatters.
Happens on most of the sleds I’ve seen with the same Doo scratchers.
At least there are a few options for folks to try.
They don't break?? That's not true at all..The Doo scratchers don't break but they also don't cool much compared to the Ice Storms.
To quote every dealer who looks at an issue on our sleds:Thats how mine look after a few rides.
Okay, just not as much as the traditional scratchers when accidentally backing up.They don't break?? That's not true at all..
what are the stacool 3 scratchers you are talking about? can't find the 3. link?I wholeheartedly agree the OEM Poo scratchers are complete garbage. Go out in your garaqe and drop your OEM scratchers to the floor, guess what, those two coil scratchers won't even touch the concrete, much less hardpack snow. I broke three in two rides, bought the Staycool 3 coil scratchers that actually exert a little down pressure, they last forever, and actually cool your sled. Garbage equipment, such as the OEM scratchers make me wonder if there is any R&D/Test Rides that are performed prior to any sled release. Give me one to test, I could have told them they needed an improvement in about 100' on the trail!!! Why they haven't improved on this in 20 years is totally incomprehensible. I went for an early morning ride today, seven miles down a frozen trail, had I had the OEM scratchers on I would have had to turn around and go home, as several others did.
What is this? I can't find anything by that name.Staycool 3 coil scratchers
Hopefully they fixed the jackshaft and fuel management and bogging issues so there wont't be! The 2022s have a lot of potential.Polaris must have built one hell of a sled if the biggest complain is the scratchers.
