Strange bog while climbing
Ryanlilly
I have an 02 edge with an aerocharger turbo kit. Ride between 3 and 6k. Running #10 on straight 110.
I have an intermittent bog while climbing. Seems to pull just fine then all of the sudden it's like someone threw a plastic bag over the intake and chokes off the air.
I know most you guys run efi, but any help would be appreciated!
Here is a video, it's kinda hard to hear but the bog happens right about 3:30. The vid quality is poor, from my cell phone.
https://www.youtube.com/watch?v=ni5-drpWMok&feature=youtube_gdata_player
just before you fell off rite ? nope dident hear it but check your secondary ,mine did that when the spring got soft
If you think it is a fuel issue. Check your supply line in the tank. Pull the rubber bulkhead adapter and fuel line from the front of the tank. Check the internal hose slip/barb connection(loose). Check the screen/filter on the end of fuel line, if it is worn out you will need to clean internals of the pump and carbs.
Yea, right before I fell off.
It should be fine only 4 rides on it, but I'll pull it just to make sure.
I assembled everything just before this season, but anything is a possibility. I'll check.
You probably have checked this already but inspect your tanks vent line. Have seen them pinched/melted after rollovers.
I think I have figured out my problem. I might have been collapsing my intake tube on long pulls. Mine is just like the one in this picture.
Sent from my HTC Glacier using Tapatalk 2
That pic isn't my sled, that was a new sled that runs the same kit as I do.
This is mine.
That is clean. What happened to your old avitar Ryan? Did you axe it due to my comment?
BTW....where you buying your Av fuel?
Lol, no! Just changed it up.
I'm running sunoco 110, I get it at Don smalls 76 in Auburn across from Auburn high school. They sell it at the pump.
