Hey guys, I'm getting ready to put new top end in my 08 dragon 800. I see the "fix kit" is the way to go. So it has shim that goes under base gasket? how does making the cylinder taller eliminate the piston slap? Are the pistons different size than stock?
The kit has a quarter inch aluminium shim that installs under the cylinders to accommodate the taller pistons. I am not sure about the science behind the taller pistons, I think they are more stable. The pistons are a little bigger than stock for tighter clearances. This is the link for the kit. For additional questions, call these guys up. They are very helpful, and will be happy to answer any questions. http://www.pmspolaris.com/FIX-KIT-F...l.htm?productId=-405614&catalogId=-3275&fpg=1 I am also in the process of rebuilding my 2008 800 and it is really quite easy.
When you buy the kit, you will also have to bye some things that aren't included like gaskets etc. Good luck.
