Is it worth the expense and hassle of a turbo to run 4-6 lbs boost? I keep hearing about good running N/A mods keeping up with or beating them?
Not on my T-Pex at 12 pounds WOOOHOOO!!!!!
A PGM8 at elevation, say 10K-12K, is a very potent little sled. You can run 7-8 lbs of boost and be safe. I guess it all depends on your elevation.
How is 7 psi at elevation different than sea level?
Density is simply the number of molecules of the ideal gas in a certain volume.
In order to achieve a certain psi you need x amount of molecules in a certain volume.
7 psi at altitude = 7 psi at sea level when it comes to the amount of molecules.
And would it be safe to say that if the density of oxygen is less at altitude, you will loose X amount of power. Yes, 7 psi is 7 psi, but the number of oxygen molecules in that 7 psi will be less at altitude.
Not sure the conversion, but may need to run 9 psi at 10,000' to be equivalent to 7 psi at Sea Level.
Octane is a function of air density, right??
