What He said^^^
That MORE than doubles the clearance compared to running the 8 tooth 2.86" pitch drivers with the 2.5" CE track.
to do the PC with 7 t. drivers..you need drivers, anti stab kit, cut rails back, trim mini lugs in PC ....steeper aproach angle,
with the 2.5 camo..and kurts(fastrax motorsports) D&R, you gain over 1 and 1/16 in track to tunnel clearence, stock drivers work fine, way better aproach angle, sled climbs on top in deep snow better then stock...you also have the option to go to a 3 in track if you want..it will bolt right in...
dollar for dollar, and labor for labor..they work out to be about the same cost..and a big advantage of the extreme..it is a very strong durable track...where as the PC has had quite a few reports of damage, and ripped in half..both tracks are good..but I think the extreme shines in far more types of snow then any other track..but it is a heavier track..(on my 08 D-8 163 I get the same track speed as I did with the 5.1..yet the sled goes far better then it did with the 5.1......I had more problems with trenching with the 5.1 and stock clutching then I have had with the extreme..and that was fixed with minor clutching changes... also ..the extreme stops much better down hill then the stock track...
and I started out wanting the PC..but after riding with a couple 09 M-8's.. and a dragon 7 with a 2.5 163 camo extreme..the extreme was far more impressive in our snow..JMHO......
