well we talked about surface hoar and depth. Did we make any mention of just a simple rain or ice crust?
Does the temp at which the snow falls and it's moisture content make a big difference for stability? I mean how does the wet heavy snow of 32 degrees compare to the light fluff ball snow of 0 degrees?
to further that, or the idea of how its dangerous on one aspect MOST of the time, but when it reverses, it can be VERY dangerous.PhantomCat, I like your aspect answer.
To further the discussion, here is what troubles me about avy education and snow science....very few things are true ALL of the time. So not having a full understanding of the issue can really bite you. For instance it was stated that the southern aspect gets more warming from the sun so the snow consolidates more quickly leading to a generally more stable snowpack, which is all absolutely true.... EXCEPT later in the spring when the sun is more intense and creates greater melting in the snowpack. When that happens the southern aspects can become dangerously unstable in the mid-late afternoon while the Northern aspects are still safe. This can especially be an issue in Alaska and Northern Canada where you can ride well into May or even June and have 18+hrs of sun. Everytime I think that I have a concept wired someone will throw an exception at me. It keeps me a little scared and wary of the avalanche dragon, which I suppose is a good thing.
This is a great thread. Thanks to MtnPull and others for putting in the time and knowledge required here.
Trigger points are weak points in the snow or in the slab layer. For example we say a slab breaks above us while on a hill, this is due to the fact that the slab of snow you are riding on is blown thin at the crest or near the ridge of a hill, this crest or ridge can be a slab trigger point. Another popular trigger point occurs around rocks that are near or above the snow surface. Trees and other vegetation can cause avalanche trigger points, snow does not bond to rocks trees and vegetation like it bonds to more snow. Once you add a sledder to the mix this causes these weak points to fail = avalanche.
Here in Utah the majority of our avalanches occur the first 4-6 weeks of the snow season (Dec-Jan). during this time there are MANY trigger points exposed in the snow pack, the snow is not settled and bad things happen. usually if we can make it to new years without incident things look much better throughout the mid-late winter.
....I love snow
Mtnpull, analyze the current weather system affecting Washington state right and the possible scenarios that could come of it. (if you would)
What should we as sledders be watching for once the snow flies following the current high pressure event.
I believe I know the answer but this may be helpful as a scenario we can learn from.
