Depth Hoar:
Looks like:
Sparkly, larger grained, beginning and intermediate facets are square 1-3 mm, advanced facets can be cup-shaped 4-10 mm.
Feels like:
Loose, runs through your fingers, granular, crunchy when chewed.
Smells like:
The ground. (because the rapid diffusion of warm, moist air from the ground causes depth hoar)
Also called:
Temperature Gradient (TG) (but this is an outdated term) sugar snow, squares, sometimes incorrectly called "hoar frost" by old, rural geezers.
Formed:
From large temperature gradients between the warm ground and the cold snow surface. Usually requires a thin snowpack combined with a clear sky or cold air temperature. Grows best at snow temperatures from -2 deg C to -15 deg C.
Mechanical Properties:
Behaves like a stack of champagne glasses. Relatively stronger in compression than in shear. Fails both in collapse and in shear. Especially nasty when it forms on a hard bed surface. Commonly propagates long distances, around corners and easily triggered from the bottom--your basic nightmare.
Persistence:
Extremely persistent in the snowpack from several days to several weeks, depending on temperature. The larger the grain, the more persistent. Percolating melt water in spring often re-activates large-grained depth hoar. Depth hoar is guilty until proven innocent.
Distribution Pattern:
At mid latitudes, mainly on shady aspects (NW-NE). In very cold climates, forms on warmer slopes (sun exposed, near fumaroles, non permafrost areas). At arctic and equatorial latitudes, it shows much less preference for aspect.
Regional Differences:
• Continental climates: extremely common throughout the season. Often makes up the entire snowpack until about February.
• Intermountain climates: Common before about January.
• Maritime climates: Rare and usually in the early season.
Forecasting considerations:
Never underestimate the persistence of faceted snow as a weak layer. Makes large and scary avalanches. Carefully measure temperature gradients across the weak layer. Large gradients mean the snow will remain weak, small gradients mean the snow is gaining strength but it takes several days to several weeks depending on temperature.
Best Stability tests:
Explosives tests, cornice drops, Rutschblock, compression test, test slopes.
Routefinding Considerations:
Easily triggered from the bottom of a slope or from an adjacent flat area. Pay attention to what your slope is connected to. Depth hoar avalanches usually triggered from a shallow snowpack area--avoid rocks outcropping in the middle of a slope.
Watch the video here:
http://www.avalanche.org/~uac/encyclopedia/depth_hoar.htm
I didn't even know such a thing happens. Good to know but all this will still not replace all your saftey gear.
Thanks
