good pipe overall, do the pro cogs to drop ratio a bit and let it rip, cogs on ebay for about 100 a set used take offs
Do you use the Axys belt with the pro gears?
Early builds had lots of failures with the cracks developing around the temperature probe. I have a new build and it too cracked and required welding after one of the gear clamps broke and fell off. These clamps are very important to stop the pipes from rattling apart. SLP supplies some heat tape to put under the clamps but I feel you have to add more to keep the heat off the clamp to keep it from failing.
If the clamps get too hot, they either get brittle or loosen off from expansion.
All i did at first was add heavier weightsAnyone running the slp pipe and can without the clutching?
What clutch set up you running in it now?
Who are you asking? Right now My clutch is what came stock, have not touched it.
