I want to buy a pair of the slide kicks . Please tell me where to look for them.
Right here..
http://snowest.com/forum/showthread.php?t=39767#post11891
These scrstchers not only make it snow but they also make the Holz scratchers tougher I have decided to try these as soon as I break another holz (went through 2 sets last year) and now they look like new at mid season.
I would like to see a picture of the slide kicks mounted on a snowmobile. Anyone have any pictures?
OK, question for you. The "old" design had pretty good spring tension, forcing the tip down into the trail surface for a good ice "spray". The only concern I would have is this.....will this new cable design have enough downward force pressure to significantly penetrate the trail/ice surface for a good ice/snow spray for lubrication?
Try SummitSeekers scratchers. After what Ive put mine through Im starting to think they are unbreakable. Im sure a lot of others will agree. There are countless problems with the cable style but the only problem with the spring loaded is reverse. Sounds like a no brainer choice to me.
I had them on my apex last year, two rides and they damaged my rails from bouncing off the trail. Looked like someone took a center punch to my rails about fifty times. Not impressed![]()
We would like to hear from you guys if you are having troubles.
We have about three times as many out this year than last and so far the consensus has been that they work well -and as advertised, with about a 2% complaint ratio (which have been handled promptly and resolved).
-What many dont understand is that the Slidekicks (or rather the polypropelyne coating on them) gets stiffer as it gets colder, meaning that they dig harder as the snow gets harder due to freezing. At 20*F, they have about the same resistance to flex as the traditional style but at 32-40*, they will tend to be more flexible and therefore do not have the same amount of downpressure.
We recommend that you do not have them down in this condition as there is little need for scratchers in these temp ranges anyway because of the softening of the snow due to thawing. If you do choose run them in this temperature range you will see drop in their performance.
We wish we could say that the Slidekicks will even work on the moon, but that's obviously not the case. In our design considerations we have had to aim for a narrow temperature variance window in which the Slidekicks need to operate, if we make them stiff at above freezing temperatures, the coating will tend to crack at 0 degrees, simple as that. It's just the nature of plastics.
If any of you want to go back to the spring style and put up with a total loss of your investment every time you break a set, there are many companies out there making them and we would be happy to refer you to them.
Happy new Year!
