H
true full float rear axles will have a small ring of bolts outboard to remove the axle without lifting it off the ground or removing the wheels, all 1 tons and some 3/4t hds
IT'S YOUR LIFE DUDE, SOUNDS LIKE YOU MADE UP YOUR MIND, PUT THE DECK ON AND SHUT -P, YOU ASKED, MOST ARE TELLING YOU TO BUY THE TRAILER, YOU THEN CAN HAUL 4 SLEDS HAVE NO PROBLEM, YOU MAY BE ONE OF THE TRUCK DRIVERS WHO WILL MAKE THE NEWS AS BEING OVERLOADED AND KILLING SOMEONE OR YOUR FAMILY, i SUPPOSE YOU DON'T HAVE HELMETS EITHER, YOU MUST BE A RENEGADEDude just asking a simple question and want some honest answer dont need smart a... comments. For shure I dont need you to tell me its ok to run a sled deck If I wanted too I would. Like I said before I drive truck for living and 10 times out one the vehicule is over weight so I now what is over weight/ I was just looking for people that are running 1/2 ton trucks with sled decks how the truck is outfitted. Why dont you quit your bull s... keep your comments to yourself. Thanks
not sure about anywhere else, but in b.c. when they do there dot checks in golden, which are quite popular, if your over on your 1/2ton you will be leaving a sled there before your rig goes anywhere, its that simple. buddy had it happen to him, had to make a trip back from calgary to get it, where he left other one, then got stopped here in sask again by dot, they weighed him up, over on rear axle limit, no ticket but if they seen 2 on there again, it would be impounded with a fine.
according to the ford trucks site, the 2008 f150s have a payload of 3050lbs, is that for real!?
Beware, a lot of 3/4 tons have semi floating axels now days. They are just bigger than the 1/2 tons. Another reason to go with a 1t.
According to the ford trucks site, the 2008 f150s have a payload of 3050lbs, is that for real!?
I don't know what your province / state regulations are, but in Alberta and BC you cannot carry 2 on a sled deck unless it is a 3/4 or 1 ton. A little more food for thought - the driveline / rear axle and wheel bearings on a 1/2 ton may not like the extra load very much (u-joints, steady bearing, etc). Not to mention you may experience brake fade on longer downhills. IMO, I'd go for the 4 place and run trailer brakes...
