What pitch are your drivers?
If they are 3.0 pitch, those 7t drivers will gear you down from about 2.09 to about 2.27. That's a bonus.
Beware that your clutching won't perform exactly the same now.
You'll rev quicker.
The faster you go, the more your speedo will be off.
When it says 40mph, you're more actually like 43.5mph.
I thought it was the other way around? You are putting smaller drivers in the track which have to turn that much faster to cover the same ground making your odometer add more miles than was actually covered.
Help me out there then.
I looked at it the other way around.
When you gear down, your revs go up at slower speeds.
So when you are turning 8300 now, you aren't moving as fast as you used to be.
Think of your stick shift truck.
(and I'll make some nice easy to use numbers)
You are used to driving in 5th gear at 65mph at say 5000 RPM.
If you gear down and leave it 4th gear but try to drive 65mph, you are doing probably 5500 rpm now. You are over-revving.
So if you were to drive at 5500 4th gear, you certainly won't make it to 65mph. You'll be down in the 50s, somewhere probably.
Our RMKs are clutched to stop shifting out at say 8300, no matter the track speed.
Lower gear, you get that target RPM quickly, but you are NOT getting to your same MPH.
This is also why simply gearing a sled down in the chaincase/belt drive does not affect the speedometer but changing driver diameter does.
Well technically changing gear ratio on the belt drive sleds does mess with the speedo, changing it on a chaincase sled does not. The Speedo Sensor is on the jackshaft on belt drive and on the clutch side of the driveshaft on chaincase sleds. At least this is true with a '12 chaincase and '13 belt drive, correct me if I'm wrong.
A little confused.I hear the new 2.6 track will not work well in the 2014 & 2015 chassis. Not enough clearance. Will 2/10" really make that much of a clearance problem? What other differences are there between the 2.4 and 2.6?
True back then, but all 16' models have the sensor on the brake disk now
I believe there are 9 holes in the brake disk that the speed sensor works off of. Has anyone successfully closed off one of these holes to reduce the speedometer output to 8/9ths of its original reading in order to get the speedo a little closer after gearing?
