does the filter have a serial number on it. Finally looked at the cpc web site, The price on that is ridiculous.
one thing to think about, if you run hose in between the filter and T/B it needs to be stiff enough not to collapse,
I didn't like drilling the holes, but it's held up pretty well even after a good hit. QUOTE]
Do you think radiator hose would be stiff enough? I have also thought about running a hose off each throttle body into a Y and using one bigger filter that I already have. The other issue is to put the sensor. What does the sensor in the air box do? Is it necessary or could a guy just disconnect it without any issues.
Its a air temp sensor, you need it and needs to be in the intake, If you have stuff use it but bring the other stuff just incase it doesn't work, I would try to build and adapter like the cpc kit, if you had an old air box to cut up it would be easy.
you going to the boise snow show
