I've been trying to figure this out since the end of last season. Can't get it out of mid-range, bogs and sputtters. Some times it will get to full rpm but only if you go from nothing to full throttle, it you back off the throttle a little and ask for it again it bogs out and looses power. This year already I have replaced the stator, new tps, new tps harness. Cleaned the exhaust valves at the end of year last year might pull them and clean them again in case I missed something. New plugs and tps is set to specs. My next step will be to try to go through the wiring as good as I can, this problem is really kicking my but!
The computer doesn't bring up any codes.
Could this be an injector problem? And how can you test them?
The local dealer doesn't have a clue and doesn't seem interested in helping. If anything stands out or any good ideas I would appreciate the help. You guys on here seem to know way more than my local dealer.
Thanks!
Thanks!
