Running board edge front bracket replacement?
seth25
The front bracket on the running board edge where the board bolts to the steering tube support is broken on both boards. Parts fische does not show this part separate, looks like you have to buy the entire board edge.
Does anyone know if you can buy the bracket separate? They are glued in with one rivet on the inside and have already removed them.
Thanks
I would be looking for some one who has put on Skins Air Frames..
They remove the stock outer edge rail with the end piece u need.!
I have seen them for 100 a pair the cheapest!
Good luck..
Check SwapMeet!
I bought the sled damaged and am doing a tunnel/ bulkhead replacement. I am looking to do airframes this summer. There is still a ton of snow here in Colorado and airframes are 4-6 weeks out, so I am looking for something to get me by for the remainder of the season.
Sorry, accidentally gave you a thumbs down when doing a quick reply!!
Are you talking about the toe stop #7 or the tab that is on the running board support that bolts to the #6 asm frame?
I got the running board support a couple weeks ago and the asm frame last week. Both were on back order. The toe stop was available. I took a nice stump right where all that comes together. The tab on my running board support snapped, so I used some plumbers tape to wrap aroung the running board bar and bolted it back in place. 400 miles and harldy notice it's all rigged together.
I use polarispartshouse.com to get these pics. Makes it handy to go to the dealer and tell them exactly what I want.
The tab on the running board frame that bolts to #6. Both sides are broken. The toe stops are still in good shape.
I found a set of airframes in stock, so I went ahead and pulled the trigger on them. No more need for these brackets, thanks for the suggestions.
