Interesting responses. I have only had the det light come on twice this winter, once it came on steady, not flashing, and still held RPM, I let out on the throttle and it went off. The next time is was flashing and retarding the timing. But I was almost out of fuel, I filled up with reg 87 as always and it hasn't come on ever since. Figured I might have had some bad gas. My reason for running it isn't to see if I can get more power from it, I understand that for it to make a real difference I would have to have motor work done. But I was hoping for some more RPM possibly, or just a better crisper running sled. Polaris now wants us to run 92, and the only 92 I can get (PetroPass) is watered down and has methanol in it. Which polaris also doesn't want us to run in these motors. So I have been running good 87. I was thinking I can't lose if I'm running closer to what these motors want.
My current set up is 10-66's, slp green spring, which has a higher start and finish rate than stock, and a PC5 with dyno tecks second latest stock map. My R's are still at 7900-8100. Now and then I"ll see higher. It ran absolutely AWESOME for a while after I put the PC5 on it, (8250- 8350) but has come down quite a bit. Totally stock D8 with PC5 that I ride with is pulling 8300 with stock 68's and stock spring, so I'm not sure why mine is low. I figured it might like some more octane. Like I said it seemed to run stronger, but it's hard to compare, as earlier on in the day with straight 87 the snow was really wet, and when I tried running the mix it had hardened up some. So hook up was better. But it sure wasn't running worse, it hasn't run this strong for quite a while.
Thanks for figuring that out F-Bomb. I was wondering what kind of number I would be at now. My ratio was probably a bit off, as I don't have a really accurate way of measuring how many liters I put in, but it should be close. I'll keep it at about this mix for a while and see how it runs in the long run with it. Only got out for about 20 min last night to try it out. Plug gap is about how the plugs came, if I had a feeler gauge I might play with it a bit.
