Well, I had planned a few more things over the summer but clutch "trouble" slowed down progress. That being said I think the sled looks pretty good and the new mods should work out well.
New rear tunnel section ( built by me )
New 18" Fox Floats -5 lbs
Changed stearing post out to T style, XP riser, and RSI 2" rise bars
Relocated all the switches to the dash
Took 6 lbs out of the skid ( adjuster, one strap and the last set of bogies and some holes )
Boss seat -5 to 7 as I never put the new seat on the scale
New primary, 12.3 empty pins and 1mm oversized roller 2.5 grams over stock
Removed 19T jumped up to 21T ( stock was 23 )
Floating secondary.
Sled is down 15 more lbs and I'm down 20 so far... should be a good year.
Rear skid is the next step, my skid is 48 lbs the way it is ( with worn out hyfax and cable scratchers ) If I can ditch the stock torsion springs and steel bodied shocks for a single float I would be about 38 lbs and that would be a pretty big improvment over what must have been close to 57-58
lbs stock but the budget is taped for now, need to focus on some new riding gear.
Floating secondary.
