Want to hear about anyone that is running lightweight rotating parts like titanium clutch bolts, lightweight clutch covers, etc. Does it make a noticeable difference?
Yeah thats for sure, but is it worth it?
I'm making a few changes in this area this season, as well as adding boost. I am doing them all at once, so I won't be able to report on individual changes, but here are some photos documenting the weight difference for those who are looking into it.
So, all said and done, a 12.4 lb loss of rotating mass.
Thanks for the feedback guys. Keep me posted on your results when you get your changes on the snow. I am for sure considering the conquer track, would just like to hear a little more about it once people really start riding it and not sure whether to stick with the 2.86" pitch or change drivers. I have a 155 2.6 track with sidekick but was also considering the lightweight clutch covers and things like that but have not heard if they really make much of a difference.
You're going all out. And did you weigh your wallet before and after?
I see you've resurfaced. This is something I do not believe your qualified to comment on. These guys pay for their parts.Nothing new for a sledhead
From an engineering perspective, the reflected inertia of all the drive train components and overall weight of the sled, back to the motor crank shaft is a function of 1/gear ratio squared. This plus the inertia of the crank and primary clutch determines the overall inertia of the sled. When the primary clutch first engages and hasn't started shifting, the sled theoretically accelerates the fastest as the reflected inertia is the lowest because the gear ratio is high. At this point about 7% of the motor torque goes to accelerating the crank and primary clutch, 1.5% goes to the secondary, 90% goes to the sled, and the other 1.5% is the other drive train components. I did this analysis by estimating the weight of all the drive train components with the weight of the sled and rider at 600 lbs. Once the primary flashes to shift speed (8000 rpm) the inertia of the crank doesn't matter anymore as it stops changing speed. So from there on 97% of acceleration of the sled is determined by the weight of the sled and rider. (and power of course)
When I first got my 2016 AXIS 800 rmk with the lighter weight crank I could definitely feel the difference in throttle response and acceleration at initial takeoff. This makes sense given my analysis. Reducing primary clutch weight like bolts and covers will make a difference in how it feels up until it starts to shift then it will be gone.
Reducing the weight of any other rotating components from the secondary to the track drivers makes almost no difference (>0.5%). From there the weight of the sled is coupled to the track as long as the track is not slipping. Therefore the rotating inertia of the track is the track plus the weight of the sled. They are not considered separate in my analysis. If you reduce the overall weight of the sled by 10% you will increase the acceleration by 10%. To get that 10% is tuff as in this example the sled and rider is 600 lbs so you have to reduce 60 lbs.
Adding 10% more power is much easier. If you can do both like burandt, then you got something.
Cinno
Thats a whole lot of math you did there. In my experience, several of your calculations dont work out to real world results. Have you ever spent anytime on an engine dyno, and then a chassis dyno to see where your figures come from? Then making drive line changes to lighter parts to see loss or gain? I have done both of those things, several times, with snowmobiles and race cars. Did you know that only about 50-60% of the hp at the crank shaft makes it to the track?
Further more, this statement..... "Once the primary flashes to shift speed (8000 rpm) the inertia of the crank doesn't matter anymore as it stops changing speed." What stopped changing speeds? the fly weights in the clutch?
Or this statement.... "Reducing the weight of any other rotating components from the secondary to the track drivers makes almost no difference (>0.5%). From there the weight of the sled is coupled to the track as long as the track is not slipping" Again, this doesnt make any sense at all. Of course the track is slipping, and every single part in that drive line will make a difference. Eric
Seems easier and cheaper power to get the BD "boost button".
