I was told the vipec sees everything the ECU did. Even the low oil warning...
you need to swing a leg over a boost-it fueled turbo..word is they are better then stock on the bottom and the snap...but yeah getting around the hi-octane fuels lazy characteristics is going to be tough to do..wonder how neals fuel system on a BB would do ?
Is/was the det sensor being utilized with the Vipec???
--Running small 2861 turbos is like sucking a milkshake thru a straw
--2871 with a high flow compressor or a 2876 allows for more volume and breathability
Then mine must be a watered down milkshake Haha cause it flows just fine for my conditions.
Two strokes need more air flow then four strokes, that's why yours works well.
My Silber is a 2860 on my Pro, and like I said seems to flow and work just fine. But here in California we don't get that bottomless powder with huge loads to bring the charge temps up so high.
I agree if you are riding different deep conditions all the time the 2871 would be a better choice but here in California its not needed.
Good to see you took it for a spin Scott, are you sold on it?
Guys just to clear some things up a little.
The pump gas setup on 7 or just over 7 in the trees is awesome and you actually dont need any more than this it gets to be uncontrollable especially with a 163" track.
Avgas setup has a slight and I mean very slightly slower burn to it but nothing to worry about for the high boost application. Ive run both apps and very small differences in throttle response. The timing control helps this tremendously.
I've helped all the guys above to get them going with the Vipec and have to say by the way it looks next season is going to provide alot of options for high performance applications.![]()
Yes, it was fun. I do like it. I got used to the throttle, and after about 15-20 minutes I was much better at boondocking it.
So to counteract that bottom end feeling, can you run more timing down there?
That being said... I think that there could be some improvements made with a custom fuel blend just for these "Tree Riding" everyday turbos on lower boost that work at a high load (like sleds do) IMO... a big diff.
Something like a TRUE 96-98 MON non leaded fuel, with good RVP and 90% evap numbers... Not really seeing something that would be Ideal for turbo sleds yet in the way of "race gas".
The typical 110 or 112 octane race fuels are not tailored for the cold weather an fast throttle transition cycles that we see here...
Here is a video of a HM Pro running the Boost It fuelbox.
thanks for your reminding us you are a boost-it freak, totally out of context!!! we all watched that video in his original post.....where it belongs. For someone telling other snowest member not to hijack thread, banned them for a week, you are not preaching by example for sure . just showed everybody,again, you are nothing but impartial and do not deserve your super moderator status one bit.
I like the HM turbo,you got a problem with that?
ok Dave, never mind, we are all stupid.....do you really believe we're not seeing/understanding what you are doing?? talk back to you in august(taking a summer brake), just a tiny bit before haydays(hope you are coming to visit , our boot is just beside arctic cat USA and i will PERSONALlY entertain yourself about our new plugin ECU for the 800cc 2 stroke arctic cat and 1100 turbo 4 stroke)....we never know,we may become the best of friend![]()
