RMK controls
Seabass152
I may be getting a 11 RMK due to an insurance write off of my 09 Dragon. Dealer doesn't have any Pro's left and just this one RMK that I would get for a good price. Has anyone switched the RMK controls to Dragon/Pro style?
Thanks
The standard RMK, I believe, has a "T" type steering post while the Pro models have a "plate" type steering post. A simple swap of bars and risers may not be possible.
This is true, but i wasn't so much asking about the bars as I was the heater, high beam, mode buttons and swapping to a Pro style master cylinder to clean up the bars have a more durable set up. My 07 had the RMK style switches/brake and I seemed to break that switch assembly a few times in roll overs and it sucks to deal with.
not worth swapping over as it requires quite a few parts ect...better off ordering a 2012, or waiting for a "not picked up' snowcheck
Do you still have those parts from your totaled sled?
If not, the parts you are asking for are pretty pricey and will also require you to cut up the harness... which could void your warranty on the electrical (ECU/Regulator/etc) as well as the engine.
Glende Polaris in Chico has an '11 Assault for sure, and possibly a 155 pro. You can probably get a good deal on either as they probably don't want to keep paying interest on having them sit there. If you do call, let them know Pike sent you that way. Thanks and good luck.
its possible but you would have to buy the switches, cut up the harness and wire in connectors to connect to the switches.
