RMK 600 can question?
I have a 2012 RMK 600 144. Im looking into the SLP can or Skinz Ultra Q. Is it true SLP can doesnt void Polaris warrenty? What about Skinz? My only concern is it effecting reliability of motor. I dont want something that could/will effect motor. Which would be a better choice?
Thanks
First off skinz is backordered like 4-6 weeks. The SLP can is a very well made can but drops very little weight and does not sound much different. I installed a GGB on my 600 and it sounds great and gets my vote. By the way any can will void warranty if the dealer chooses to do so.
Run what ever you want. Replace with the stock can if you need warranty work.
600 Cans
Neither of those cans will have much of an impact on airflow, so won't create engine issues. The Ultra Q is noticeably louder than the SLP at high RPM.
The GGB matches the stock can for back pressure and at 10000 ft I had no rpm loss. I have run the skinz super q and it is a great can also. Most of the cans will work good. HPS is another good manufacturer. I went with ggb over hps because it was 70 dollars cheaper.
Where did you get it? I am interested in one for my 2013 Pro 600. Is it obnoxious?
GGB CAN
I have the GGB trail can, they also make a mountain can, the trail can is slightly
louder then stock on the top end but not by much, the mountain can is much louder on top, both will not lose power, the mountain can will lose close to 7 lbs and the trail can is around 5.5 to 6 lb. Do a search on here or on Youtube for a video.
www.GGB.CA to order.
First off skinz is backordered like 4-6 weeks. The SLP can is a very well made can but drops very little weight and does not sound much different. I installed a GGB on my 600 and it sounds great and gets my vote. By the way any can will void warranty if the dealer chooses to do so.[/QUOT
I talked to Skinz today and he has Ultra Q in stock. It is what I am going to put on my 600 Pro
Any feedback? RPM gain/loss. Would love to hear it any vids? Did you get the trail version?
